Hi everyone !
This is an interest check for Krytox GPL 205 Grade 2 grease
Compared to Krytox GPL 205 Grade 0 the only difference is in consistency:
Grade 2: Normal Grease (Peanut Butter Consistency)
vs
Grade 0: Very Soft Grease (Brown Mustard Consistency)
Grade 2 has the same uses (stabilizers,switches,topre sliders etc.) but is thicker and for that is a bit better for stabilizers but needs to be applied very thin on switches or you can mix is with a bit of GPL 105 oil.
If enough interest is gained, I will pack them in 10ml containers, of which you can get multiple. Shipping anywhere, check the interest form for more info.
Google Interest check form here : https://forms.gle/JxbK4HPhAUHMLA2t5
This will be active until Friday 22 May 2020.
If all goes well and we have over 200ml in orders, I will move forward and they should be shipped to you until 30 May 2020.
Thank you !
