Hello everyone,
We are excited to release the first keyboard for the MKC series—MKC75. We have worked on this project for around three months since we do the polling on our channel. And finally, bring it to you all.
MKC series is planned to do some more budget keyboards. We aim to make it affordable and accessible for most customers, enabling truly entry custom keyboards comparable to mass-produced, which can be easily purchased. Therefore, The product positioning of the MKC series is an entry-level customization kit for mass production.
Now, let’s check out the MKC75 together!
Features
- Supports Caps Lock Indicator Light
- 100% processed using CNC machining with 6063 aluminum case
- Compact 75% layout
- Three-in-one structural design( Top Mount, Plate Gasket Mount and PCB Gasket Mount )
- Supports tri-mode PCB(Wired, Bluetooth and 2.4ghz)
- Supports Plate, Half Plate and Plateless Build
- Supports rotary Knobs components, which are also compatible with JRIS75 Rotary Knob/Badge/LED Light Sign
- Supports Alu Internal Weight
- Multiple configurations available
- 2 x 2200mha large battery capacity
- Dimensions
Three-in-one Structure
We have adopted a three-in-one structural design for the internal structure, which can support regular positioning plate gaskets, PCB gaskets, and the long-disappeared TOP Mount structure. Thanks to the consistent frame of the compact 75% layout, we can make the three structures perfectly compatible.
- TOP Mount
- Plate Gasket Mount
- PCB Gasket Mount
More than 17 Case colors available
We adopt 17 case color cases and want your ideas for other new colors.
- 4 E-coat case:E-white, Milky White, Pink, Lilac
- 6 Anodized Case: Orange, Black, Brown, Grey, Silver, Green
- 7 color combos case:E-White&Black, Orange&Black, Grey&Black, Silver&Black, Red&Black, Blue&Black, Green&Black
More than 10 Weight colors available
- 4 Alu Weight: Gold/Silver/Black/Rose Gold
- 6 PVD SS Weight: Gold/Silver/Black/Blue/Gradient/Chroma
More than 6 PCBs available
- Wired Flex Cut Hotswap PCB( 1.2mm, Multi Layout, No Per-key RGB, 7u split spacebar,support QMK and VIA )
- Wired Non-Flex Cut Hotswap PCB(1.6mm, Multi Layout, No Per-key RGB, 7u split spacebar, support QMK and VIA )
- Wired Solder PCB(1.6mm, Non-Flex Cut, Multi Layout, No Per-key RGB,7u split spacebar,support QMK and VIA )
- Wired Per-Key RGB Hotswap PCB (1.6mm, Non-Flex Cut, ANSI Layout, support QMK and VIA )
- Tri-mode ANSI Hotswap PCB (1.2mm, Non-Flex Cut, No Per-key RGB, support Mykeyclub Software)
- Tri-mode ISO Hotswap PCB (1.2mm, Non-Flex Cut, No Per-key RGB, support Mykeyclub Software)
Noted: The Tri-mode technical support is provided by IRISLab. Really appreciate their support and help.
More than 7 Plates available
- Flex Cut Plates: FR4, ALU, Brass
- Non-flex Cut Plates: PC, POM
- Alu and FR4 Half-plate
- Plateless
Mykeyclub Team
We feel incredibly grateful for our community’s support. We will keep working to bring creative products and lower the threshold of building everyone’s dream kit for daily use.
Please fill in the MKC75 IC form to share more thoughts and ideas on this project. And join Mykeyclub Discord to share your ideas and discussion on our channel.
Thank you so much.
Best Regards
Mykeyclub Team
