10th Augest, 2018
All layouts are adjusted.
Will make by Maxkey.
Add ‘Minila’, ‘660’, ‘full short space bar(Among them, 2.25u, 2.75u, 2u, 1.75u are sink space bar)’, ‘40%’layout,etc…See the layout for images
Delete some 1.5u novelty key.
15th July, 2018
Add Ergo kit.
27th June, 2018
New layout for SP.
4th June, 2018
Novelty kits add a yellow return.
Modifiers kits add a R1 1u purple ‘~’
Considering the identification, whether the novel keys of R1 are needed. If the number of requests is large, it will be added again, and there will be a total of 12 patterns
About
Inspiration comes from Stephen Hawking’s prediction.Salute the great man. :thumb:
The design continues to be updated.
Quick question, maybe a dumb one: How did you get the CA-66 render model? Did you build it yourself or did you find it somewhere?
I’m trying to build renders for a keycap set I designed and can’t seem to find any pre-built models for custom keyboards, but I do not know if everyone builds them individually or what…Thanks!
like the colorway. great novelties. defo in for a set.
Hope there will be split spacebar(keys) support. (i.e. 1.75 - 2.25 - 2.75 - 1.25)
Also a alt color for f-row kit, not a big fan of sandwich color on the f-row, especially on 96% board.
