Hello guys. Today, we are thrilled to introduce our latest keyboard designed by Keyverse studio–INFI75-“KEEP OUT!” EDITION.
The INFI75 is a triple-mode mechanical keyboard that provides a perfect typing sound with the right level of keystroke resonance.
The keyboard features modern gasket mounting that yields the perfect bounce while typing. It also features custom IXPE switch pads and an additional HI-FI pad that retains the right amount of dampening, resulting in a great-sounding keyboard with no unwanted ping or hollow impact.
Additionally, it has an LCD screen, a multi-functional knob, a versatile 75-percent layout, and even a metal weight to add a more substantial feel to the setup. The keyboard provides three modes of connectivity, including wired, Bluetooth, and 2.4 gigahertz, making it extremely versatile in use.
Overall, the INFI75 is the ideal choice for individuals seeking a reliable and great-sounding mechanical keyboard.
Render
Prototype Photos
Product link
Price
In-stock Price: 109USD
Sound Test
Features
Compact 75% TKL Layout
Original Designed High-Quality Doubleshot PBT Keycaps
Premium Qing Ji Mechanical Switches
Multi-Layered Sound-Shock Absorbing Design (Original “Hi-Fi” pad)
RGB Musical Rhythmic Backlight
Full-Key Hot-Swappable Sockets
Colorful Display LCD Screen
Finely-Tuned Satellite Stabilizers
Versatile Triple-Mode Connection(Bluetooth V5.0, USB Type-C, Wireless 2.4GHz)
Long-Lasting Battery Life
Unique “Plastic-Metal” Structure
Specifications
Layout: 75% (78 keys)
Switches: Qing Ji linear switches, Pre-lubed,
Keycaps: Doubleshot PBT, 1.5mm thickness
LCD Screen: 135240, Full-color display
Connectivity: Type-C, Bluetooth 5.0, 2.4 GHz
Wireless range: Maximum 10 m straight line distance (the distance may become shorter depending on the obstruction)
Bluetooth device name: INFI75 5.0
Bluetooth polling rate: 125 Hz
2.4G device name: 2.4G Wireless Keyboard
2.4G polling rate: 1000 Hz
Net weight: About 1.1kg
Battery capacity: 3750 mAh
Plate-mounted stabilizers
Aluminum weight
More details about Qing Ji Switches
Included
Fully assembled keyboard x1
PC dust cover x1
Type-C cable x1
Two-in-one switches & keys puller x1
Product manual x1
Additional Keep out! novelties keycaps
Reviews(TBD)
SamBoga: update in Dec
Vendors
US: Keebsforall
EU: Keygem
SG: Ktechs
We hope you like this keyboard. Please feel free to join our Discord and follow us on Instagram for more information and discussions about INFI75.
