Introducing Pixie, the ultimate macropad for the true enthusiast. Made from high-quality ABS material, With two knobs and two switches.
Whether you’re a content creator, gamer, or programmer, the Pixie offers two precision rotary encoders with distinctive detent clicks, providing precise control for your custom macros and commands.
With two Kailh hot-swappable sockets, you can effortlessly change switches without any soldering. The stable silicon base and sleek ABS frame ensure durability and style, making Pixie a versatile addition to any workspace.
Exploded View
Dimensions
Specifications
- Dimensions: 60mm x 60mm x 25mm
- Rotary Encoders: 2 with detent and clicks
- Hot-Swappable Sockets: 2 Kailh sockets for easy switch changes
- Base Material: Fine silicon for stability and durability
- Frame Material: ABS with a soft coating for comfort and an elegant finish
- Color Variants: White, Black
- Customization: Programmable with qmk/via configurator
- Compatibility: Compatible with windows/mac
- Connectivity: Wired USB connection
Variants:
- White
- Black
PIXIE SHIPS WITH
- 1 Pixie Macropad
- 1 Type-C CAble
- 1 Allen Key
- 1 Binepad Sticker
Price
$49.9
Link to Purchase: https://www.binepad.com/product-page/pixie
Use code PIXIEKEEBTALK to avail a $10 discount. This offer is valid for a limited time only.
