Hello everyone, this is the Velocifire team.
Introducing our latest pre-build keyboard product BK75, which is designed for gaming enthusiasts. The BK75 features customizable RGB lighting, mechanical switches for a satisfying typing experience, and programmable keys for personalized functionality. If you’re in the market for a new keyboard, be sure to check out the BK75!
Media
Features
82 keys gasket mount design, hot-swappable switches gaming keyboard
Wrist rest, dust cover, keyboard display stand 3-in-1
Use the Hall switch/sensor, the keyboard will automatically turn on or off when the Wrist rest is covered or spread
Removable magnetic keyboard top metal cover
Bluetooth+ 2.4G+ Wired, Supports up to 3 Bluetooth Devices, Low-latency Fast Response
Full-key with Rogers Poron Switch Pad
Customized POM switches, office or gaming are both suitable
Two-stage system switch and footstand
The wrist rest can be used as a dust-proof cover, which in turn can be used as a keyboard display stand.
The wrist rest is detachable.
The contact surface between the wrist rest and the wrist is made of aluminum alloy, and the overall touch is delicate.
Hall switch/sensor intelligent magnetic control power supply
The Hall switch controls the keyboard light through the magnet on the handrest and the switch device inside the keyboard
When the handrest is turned over into a dust cover, it can automatically power off and sleep.
When the handrest is unfolded, the power can be awakened to resume normal operation, preventing the dust cover from being accidentally touched and effectively protecting data intelligently.
Info
Price: From 79USD to 89USD
Shipping: Ships in 1-2 business days after placing order
Vendor: Velocifire (Worldwide)
Content creators (TBD)
Specifications
Brand: Bat Knight
Keyboard name: BK-75
Number of keys: 80/82 keys+1 knob
Mount: Gasket mount
Product net weight: 1.4KG
Size: 327mm*150mm(Wrist rest 90mm)*46mm
Front height: 20mm
Connection: Type-C
Battery capacity: 4000mAh
PCB: flex cuts, 1.2mm thickness
Wireless transmission distance: max around 8–10 meters
Backlight: RGB, with programmable software
OS support: Compatible with WIN, MAC OS
Anti-ghosting keys: Full keys
Cable length: 1.5m
Follow us for the latest news on our products
Please feel free to ask us any questions and welcome to join our Discord and Instagram for more discussion and updates, thank you so much! ![]()
