Dumang DK6
Designed by Dumang Studio
Discord | Instagram | TikTok | YouTube
Description
Velocifire × Dumang DK6 Ergo V2 — The Lego-like Freestyle Ergonomic Split Mechanical Keyboard.
Your Keyboard Your Layout, No Pain.
No matter ANSI or ISO, gaming or work, long or short fingers, we get you covered in one keyboard. You just need to place each key anywhere you want without changing to a new keyboard.
Built-in MCU for Every Key
Instead of using a big PCB that requires switches to stay fixed, DK6 ergo has built-in an MCU for every key to contact with the baseboard and communicate with the PC. In this way, no matter where you place the key, it works. No matter what you set for the key, it restores information there separately.
10× Faster Than Traditional Keyboards
Unique co-processor with patented dynamic debounce technology plus a 32-bit ARM 70MHz main control chip ensures every demand on every key can be handled in 1 ms, no double or missed key register. When traditional keyboards normally use an 8-bit ARM 16MHz alone, they need 20 ms to handle the debounce delay. Even worse, some brands just shorten the necessary 20 ms without debounce tech, when switches age, double clicks, or missed clicks will happen frequently.
Your Personalized Keyboard
You can set 4 layers of key mapping, RGB, and macros for work and gaming. You can switch layers on keyboard, use key combinations, set RGB colors for each key independently.
Hot Swappable Switches
If you want to try a different typing experience, you can simply swap its switches without desoldering or buying a new one.
Solidly Built for Long Lasting
Its premium aluminum baseboard and super-strong NdFeB magnets guarantee superior durability. Ever since product development started in 2016, Dumang series products have been upgraded several generations. They are already tested and welcomed in China and Japan’s mechanical keyboard communities.
Switch Options
Cherry Hotswap: Black, Blue, Brown, Red, Silver
Kailh Hotswap: Box Black, Blue, KS Silver, Box Brown, Box Red, Box White
Keycap Options
white, sky blue, red, pink, gray, black (dark blue is out of stock)
Note
- DK6 is compatible with the MX switches; the 3-foot switches can be installed directly, and the 5-foot switches can be installed by cutting off two plastic positioning feet. Low-profile switches and optical switches are not applicable.
- The standard version does not distinguish between left and right. The ergo version is the opposite.
- Dk6 supports NKRO, and it can also run in 6KRO mode.
- Dk6 supports the Android system, and it can be directly recognized by the mobile phone.
- Leave a note for the exact Cherry/Kailh switch and color of ABS keycap set when placing the order.
Review
Specifications
Standard version dimensions: 206 x 147 mm
Including
88 keys = 721U keys, 16 1.25U keys, 1 set of ABS doubleshot keycaps, 10 blank 1.25U keycaps, and other accessories
76 keys = 601U keys, 161.25U keys, 1 set of ABS doubleshot keycaps, 10 blank 1.25U keycaps, and other accessories
44 keys = 36*1U keys, 8 1.25U keys, 1 set of ABS doubleshot keycaps, 10 blank 1.25U keycaps, and other accessories
20 keys = 151U keys, 5 *1.25U keys, 1 set of ABS doubleshot keycaps, 10 blank 1.25U keycaps, and other accessories
Price Info
Price: From 165 USD
Please feel free to ask us any questions about the keyboard below! ![]()
Welcome to join our Discord and follow our Instagram,TikTok, YouTube for more discussion, latest update and questions! ![]()
