Zi Yuan switches are the third product of Sui Xin Studio’s flower series. Zi Yuan is a type of iris, which matches the color of these switches. Its English name is Purple Iris. Zi Yuan switches are mainly made of Morandi color gray and purple. The outer housing is lighter, and the stem is deepened with the same color to enrich the color layering. The overall style is elegant and cool.
Media
Highlight
Linear switch with smooth travel
Fog-transparent light guide column with good light uniformity
The spring material is made of purely imported stainless steel wire from KOS Korea.
Switch Specs
Type: Linear
5 Pin
Top Housing: Nylon
Bottom Housing: Nylon
Stem: P3 (JWK’s exclusive material )
Housing color: Morandi color gray purple
Lubrication: unlubed
18mm spring
Actuation: 2.0mm±0.3
Travel: 4.0mm±0.3
Actuation force: 42g±1gf
Bottom out force: 55g±1gf
Service life: more than 50 million times
Manufacturer: JWK
Reviews (TBD)
Maker mods
Edwardtanujayaa
Zi Yuan switches use a pure nylon top housing, mixed nylon bottom housing, and improved P3 stem for reduced wobble and for a smooth typing experience, these switches are the best options for a readily available linear.
We hope you like this switch. Please feel free to join our Discord and follow us on Instagram for more information and discussions about Zi Yuan linear switches. ![]()
