Lio87 is a top-like mount, wireless, full-RGB, hot-swappable, pre-build mechanical keyboard featuring a nano-spray coated case, a large light bar, a left-side scroll wheel, a battery life of over a week, and high-quality PBT keycaps, this keyboard offers smooth, precise typing and a triple-mode connection for maximum flexibility. Without further ado, let’s check more details about it below!
Media
Features
A keyboard with nano-spray coating on the case, a large light bar, a scroll wheel on the left of the case, a USB2.0-Hub port, a triple-mode connection, a battery life of more than a week with the lights on, and dye-sublimation on all five sides with high PBT content Keycaps, smooth acting switches, six-layer inner tank filling with an FR4 plate (Apply PU film to optimize the typing sound), and an average delay of about 10ms.
Top-like mount, good consistency, strong feedback.
The first 87 layout keyboard with a left-side horizontal scroll wheel design on the market. Comfortable human-keyboard interaction.
The whole case matches the spray texture of the first-line big brands.
The filling is full, and the top case is with the poron pad. It is the first keyboard in the industry to stick Pu film on the PCB.
Content creators (TBD)
- Edwardtanujayaa
- cloudnoela
- wabisabi
- Lewis Toh
- vladintech
- dope.motions
- TAZAKEY
- daihuku
- cosysprout
- giaoheostudio
Vendor
Specifications
- Brand: GeekElite
- Keyboard name: Lio87
- Number of keys: 87 keys
- Net weight: About 1.3KG
- Size: 375mm x 160mm x 38mm
- Front height: 18.5mm
- Case material: Plastic
- Keycap
- Material: Doubleshot PBT (PBT content is higher than 80%)
- Process: Five-sided sublimation
- Thickness: 1.6mm
- Profile: MDA
- Switch
- Name: Lavender switches
- Type: Linear
- Stem: POM extended stem
- Top cover material: PC
- Bottom cover material: Mixed nylon
- Actuation force: 43gf
- Bottom out force: 50gf
- Actuation travel: 1.9mm
- Total travel: 3.5mm
- Spring length: 22mm
- Spring material: KOS steel wire imported from South Korea
- Standard factory lubed only
Follow us for the latest news on our products
