Greetings keyboard friends.
We are delighted to present to you the Sisyphus 65, an exceptional keyboard with a distinctive shape and weight. Our vision for the Sisyphus 65 was to create a visually appealing keyboard that draws inspiration from the absurdist tale of Sisyphus, a well-known ancient Greek myth. Our aim was to achieve a sophisticated design that is easily recognizable due to its uniqueness. To pay homage to the dystopian hero, we have incorporated contoured lines on the keyboard that depict the hill and the boulder.
The PVD stainless steel column represents the weight of the boulder, while the straight lines on the main part of the case top represent the hill. Moreover, we have included the Morse code “C L I M B” on the top of the keyboard, a word that is used repeatedly in the Sisyphus story. Additionally, we have used dichroic anodizing on the front of the keyboard and the metal badge to add to its charm and character.
Overall, we are confident that the Sisyphus 65 will capture your imagination and leave you enchanted with its exquisite design and attention to detail.
Product Link (6 units left)
Photos
E-White
Video
Showcase | Sound Test | Assembly
Reviews
edwardtanujayaa ( E-White)
NearLucid (Mountain Black)
Edwardtanujayaa ( E-White)
DBOKEY (Mountain Black SE.ver )
Keybored ( Forest Green)
nearLucid (Mountain Black )
Specifications
Case color
E-White with gold chamfers -
Plate Material
PC -
PCB
1.2mm
Flex-cut
Wired
Hotswap PCB
VIA Supported
Support ANSI Layout
Support Ladder Caps Key
Support Split Backspace -
Rectangle Weight - Stainless Steel
PVD Gold -
Cylinder Weight - Stainless Steel
PVD Gold -
Strip
Flat strip
Mountain-shaped strip -
Mounting structure: PCB Gasket
Case Material: Full CNC 6063 Aluminum
Typing Angle: 6.8°
Front Height: 19.24mm
Weight:1.25kg (Without switches and keycaps)
Welcome to join our Discord Server and follow our Instagram for more discussion and information about the Sisyphus65!
