Stars 75
Designed by Weikav
Color Options
Photos IRL
Difference between Stars75 and Stars75-S
- Stars75-S has a diagonal “Breaking out of the cocoon” design (Diamond Cutting Process PC material light strip) Which Stars75 doesn’t have.
- At the same time, the Stars75 has a badge on the top case, but the Stars75-s does not.
Highlights
1. Diamond-cut craftsmanship with PC material “Breaking out of the cocoon” design
The product uses high-end diamond-cut processing techniques and a PC material “Breaking out of the cocoon” design, adding a unique metamorphosis aesthetic to the product.
2.Anodizing/Electrophoresis process, 180-mesh sandblasting treatment
The product uses anodizing/electrophoresis surface treatment and 180-mesh sandblasting, resulting in an exquisitely smooth and silky touch.
3.Leaf-spring + beryllium copper structure
The leaf-spring + beryllium copper structure design provides a more solid and stable typing feel.
4. Magnetic nameplate storage compartment
The product features a magnetic plate storage compartment for convenient storage of dongle.
5.8000mAh large-capacity battery
The built-in 8000mAh large-capacity battery provides long-lasting usage time.
6.Triple-mode connection
The product supports wired, 2.4GHz wireless, and Bluetooth connection modes, meeting the needs of different usage scenarios.
7.Supports QMK and VIA
The product supports QMK and VIA custom firmware, allowing users to personalize the settings according to their preferences.
Review
Specifications
Connectivity: Wired, 2.4G, Bluetooth
Anodized (Red, Silver, Black, Purple)
Electrophoresis (Milky White)
Material: 180 mesh CNC Aluminum
Mount: Leaf spring Beryllium Copper mount
Back design: Magnetic receiver storage compartment
Back Weight: Ice Crystals Alu Weight (Silver/Black)
Personalized design: diagonal “Breaking out of the cocoon” design (Diamond Cutting Process PC material light strip)
Support QMK, VIA
Support Windows, MacOS, linux
Size: 324mm x 136mm
Front Height: 20mm
Back Height: 38mm
Weight: 1.8kg
Battery: 8000mAh
Hotswappable 1.2mm PCB
Included
Keyboard
USB-Cable
Keycap/Switch puller
Manual
Price
92.99USD+
Please feel free to ask us any questions about the keyboard below! ![]()
Welcome to join our Discord and follow our Instagram,TikTok for more discussion, latest update and questions! ![]()
