Anyone know about these? Says 5 pin. Force curve looks like a medium tactical, and KPRepublic text says self lubricating POM. Doesn’t say if it’s the housing or the stem or both.
Maybe these are a blueberry recolor with a lighter spring?
I think they are more like Polia with lower spring weight. Because kailh market them as advance tactile switch
But will it work in a coal mine?
I mean, they may die on you.
At least by the factory graphs, I think you might be right about that; here’s the Polia’s:
And here’s the Canary’s:
The return line is a little confusing given it’s supposed to be lighter, but then again factory graphs go well with a kilogram of salt.
Cream recolor with a lighter spring and a Polia / Halo stem? ![]()
Edit: nobody tell John Deere
