It has been almost a year since we posted 001 Adam here. It was an absolute pleasure for me to lead this exciting project. Later, we launched the 002 Addams Numpad, which can be seen as an add-on module for Adam. We also experimented with the modularity project Adam0110. All of these projects bear a strong KBDcraft imprint that we seek inspiration from the “Lego” world and incorporate those ideas into the keyboard world.
When we moved on to the 003 Lilith, we decided to stick with the 60% modular design but innovate on it further. Here’s what we did for Lilith:
A tilt angle. Many users had expressed their desire for angle-adjustable feet on Adam. However, we couldn’t change the force-bearing structure without a comprehensive thought. For Lilith, we completely redesigned the case to provide a 5.5º angle while remaining in full contact with the tabletop. Additionally, since the core64 is bilaterally gasket-mounted, it can be hung on different levels. If Adam’s owners want the angle, they can simply swap to Lilith’s case.
Brick-built boards can start curving when the length is > 30cm due to the cumulative pressure on each stud. Cutting off the tension can reduce deformation, but it will also weaken the structure. For Lilith, we ran numerous tests on different selections and distributions of components and found what we thought was the best midpoint. In simple terms, Lilith has a straighter and stronger case.
In EVA background, Lilith is believed to be the origin of mankind, so we thought it was necessary to give it an iso layout to adapt to all human languages.
Unlike Adam, Lilith has a very specific and clear image in EVA. Her mask with the Seele symbol is one of the most impressive features. So we invented a new game with keycaps called Keymoji, which uses high-contrast colors to create many cute expressions, just like Lilith’s mask.
Although we always smooth out the entire case, some extensibility remains. This time, we gave Lilith a pair of ball joints for flexible hooking of minifigures and other modules.
Accessories such as wrist rests and sound pads are always compatible with new models, and a keyboard stand made of bricks is being released along with Lilith. 004 Lilin should be another small-size module that can work independently or pair with Lilith. What do you think we should do in the future? Let’s chat in the comment.
