What do you think is better, jelly epoch sse or portal from parallel limited with pe foam mod to make it sound like a jelly epoch.
Also, I want to know the difference between a jelly epoch and a sse
Don’t know much about Jelly Epoch, but you can probably do the pe foam mod for any keyboard as long as it has a detachable plate
