Hello!
I’m attempting to make a keyboard case with standoffs, no middle pieces, to reduce costs.
which is similar to this: (from: littlekeyboards )
is there any issues that I should worry about? like: collected dusts after a long time of use !? ![]()
Hello!
this style has been used a lot and its a great way to keep costs low and manufacturing simple. Some dust will get between the layers, but shouldnt cause any problems - it would also be super simple to clean with some canner air or a quick disessambly.
The other nice thing about this style is that you can ‘tune’ the flexibility to your liking my moving the standoffs around your design!
