I acquired a Norbatouch casing for my Cooler Master Masterkeys Pro S. I love it but I am still using the stock keycaps from the CoolerMaster and wondered what other folks who have this casing are using? My only thoughts are that I really like the height of these caps.
Also, iirc the Masterkeys Pro S has north facing switches, so Cherry profile caps are out of the question due to interference. If you like the profile of the stock caps look for OEM profile.
To answer your original question, I’m using a set of KBDFans black-on-grey PBT keycaps on an Aerospace Norbatouch. It’s a pretty simple combo but I like it.
If you ever decide to desolder the Masterkeys Pro S, you can put in some switches with longer stem poles so that you don’t have to worry about the south facing issues causing collision with Cherry profile caps.
Also, the Kailh silent box (with the circular stems), Art box switches, and some of the new Gateron switches help avoid the issue.
I used the Kailh deep sea switch on one of my Masterkeys builds.
thanks for the info here - the BOX browns look a little more punchy than the cherry mx browns BUT i see what you are getting at. very good information.
