This is the first part of an experiment to see if putting the Greetech-made Razer Green switch leaf into an Aliaz housing can produce a highly-tactile, smooth switch.
The Greetech-made Razer Green leaf is desirable because it is similar to a Panda leaf and increases the tactility of any stem.
The Aliaz housing is desirable because it is very smooth (probably the smoothest you can get) but in stock form its leaf does not produce much tactility.
Part 1 is to disassemble all 70 of both switch types, remove the leaves, put the Razer leaves into the Aliaz housing, and then lube the lower housings with PFPE + PTFE grease (similar to Krytox).
Part 2, once I receive the Halo stems I ordered, will be to lube and install Halo stems in these housings, and test them out! Stay tuned!
