Hi everyone!
Just wondering if anyone had recommendations for LED Magnifying lamps. I’m a bit curious about getting one because I realize it could be really great to have the magnification when lubing switches
Could also be useful for soldering in general
Does it need to be lamp? I’ve found the visor/headband magnifiers to be more convenient: https://www.amazon.com/Carson-MagniVisor-Head-Worn-Magnifier-CP-60/dp/B007CDJKM2/
Rico
February 6, 2020, 1:43pm
3
I had linked this headband magnifier a long time ago:
Less expensive and should do the work well, and yes the lamp is useless on that.
But I think Huey is interested in a magnifier lamp instead…
Rico
February 6, 2020, 3:45pm
4
Probably this one would fit your needs @Manofinterests .
Amazon.com: Brightech LightView Pro Magnifying Glass with Light and Stand, Magnifying Floor Lamp with a 6-Wheel Rolling Base for Facials, Lash Estheticians, Dimmable LED Work Light for Sewing, Crafts : Arts, Crafts & Sewing
By experience, I strongly discourage to use ones with small feets as working with bigger objects like keyboard PCBs makes them nearly unusable.
I just use a desk lamp over where I work
These are all pretty good suggestions
A magnifying headband/visor wouldn’t be a bad idea either
