I’m looking for something I thought would be pretty easy to find - but since I haven’t had luck yet, I thought I’d pose the question to you fine folks.
I’m looking for a single R4 OEM profile keycap in metallic gold. It just has to look gold - zinc, aluminum, etc. are fine. It will be used as an ESC key - blank is preferable but it’s fine if it says “Esc” on it. I’d prefer solid metal to shine-through.
I’ve seen plenty of full sets, and plenty of single caps with things like “CS-GO” or WOW emblems on them, but not so much the blank ones - and the Esc keys I’ve found so far are all out of stock. Any suggestions on where to find one? Thanks!
