Hi.
Recently I purchased the KBDFans mx sliders. Stayed without drilling it for a while, but when I received my BKE domes I decided to complete the mod.
For the actuall drilling, everything went ok. To remove the extra plastic I decided to sand the holes to better fit the mod keys. After I finished sanding and put the board together I felt the worst scratchy feeling possible on the left shift and enter keys.
Just then I realized what have I done. I didn’t pay much attention when sanding and ended up sanding the sides of the housing, where the sliders… slide.
I don’t have any pictures right now, but was wondering, considering that my problem is actually the badly sanded plastic, how can I solve this problem. Maybe putting resin on the bad sanding? Or just lubbing would solve it? Maybe sand it more to make room for the resin? I can put pictures later.
Thank you guys in advance.
