The stock switches were Cherry MX reds which were very scratchy.
The switches I swapped in are Hako with 55g Sprit springs and Christo Lube MCG 129
The keyboards has silicone caulk added between plate and PCB, foam and tire balancing weights added to the bottom under the PCB. I have clipped and lubed the stabs as well.
