I got the M1 from the German seller akkogear.de, it took a little over 1 week to arrive. I have built several Keychron Q boards and can definitely say that the M1 is the new budget 75% choice that I would recommend to anyone. The quality is very good and the brass weights on the sides are a compliment for the overall look. Sadly the white version got discontinued cause of high costs for e coating i guess. They provide much foam/insulation out of the box and even deliver a sheet to use for an easy tapemod and teflon gaskets for the force break mod. It even got QMK/VIA and South Facing Leds which were the only bad points for some people. I can definitely recommend it over any other Budget in stock Board at the moment.
