I have finally built my Hidari. In a moment of keebnesia I thought I had ordered a totally different color, and so had no keycaps ready that matched it well. Did the best I could with Bushido R1.
The crazy way you connect the bottom weight gave me some heartburn, but ended up working just fine.
Essentially you put the screws in for the weight, but do not attach the weight.
You then put the top assembly on and FLIP IT OVER praying the the screws you just set in the interior screw holes don’t pop out and roll all over.
You screw the top assembly on and then FLIP IT OVER again, hoping the weight screws naturally settle back into their countersunk holes and then screw the weight on without being to see the screws through holes in the plate.
@rpiguy9907@Andreas Sorry for the late reply. The bottom one is a keyboard I designed called Skyline. The keycaps are GMK Katakana. I also took the pic under a street light at night
I think the Mojo has wider rounded edges, such as the Mojo in the bottom-right corner (but maybe it’s the camera playing tricks). I later PM’d them so I’ll def update the post if I hear back.
I got it via Kickstarter, not sure if they are for sale right now or not. It’s cheap feeling compared to my other boards, but slightly better than keychron.
