Susuwatari turned out to match quite well!
My first build. Build this month. Very happy with it but will make more boards soon.
KDBfans case, DZ60 PCB, Kailh Box Pale Blue switches and a cheap keycap set from Alie. Still not sure about the keycaps.
Pretty beginners board. Now all that you need is a set of keycaps that doubles or triples the value of your whole board.
Hand wiring is not that hard! First time using soldering iron.
My first ever custom build. Still unfinished but functionality works as expected and serve as my daily driver. Custom 3D printed case, stock kalih box navy (super heavy, tactile, stiff and loud), stock genuine cherry stabs, FC660M keycaps (white) and left over from dead old keyboard (brown).
Really cool build! I have my nav buttons set up the same way.
Those retro keys are a nice touch - I just salvaged a set from a recycling center a few days ago. They’re in serious need of cleaning but they appear to work fine like these do.
Latest iteration of an ongoing build. Link to build log: Xerox Custom Build - deskthority
My keyboard! She’s been my beautiful girl since May 2019, had an internal upgrade but caps and switches have been relatively unchanged.
Switches are 67g Tealios lubed with Tribosys 3204, stabs are genuine Zeal stabs lubed with grease and Krytox 205g0, and it’s all sitting on a brass plate, all on a KBDfans DZ60 RGB-ANSI PCB.
The case is a KBDfans Rose Wood and the keycaps are the Akko World Tour Tokyo.
Long boi is long!!! #wideputin
Not nearly as long as it will be once the track pad and case are on it
My first custom! Walnut GH60
https://imgur.com/PXUbw8m
Very unique. Perfect for a shallow desk!
Whoah, is the case wood? Walnut?!
It sure is
KBDfans GH60! I was impressed with the quality.
Emergency sticker bomb KBD75! I bought a Keyboardbelle KBD75 case a long time ago from Keyboardbelle, but when I went to put the soldered board into the case it was too small by a few mm on each side! No way it was fitting, even with sanding.
This was a puppy build for my niece turning 12, so I got the saw and drill out and made a wooden base and sticker bombed it just in time for her birthday.
Phew.
oof, could you sand/file it down to make it fit?
Sadly not. Sanding down 2mm on each side would have been brutal and I don’t think it would look very good.
