Hello everyone, this is the Velocifire team. Happy New Year! We want to introduce you to our latest pre-build keyboard product BK75, which is designed for gaming enthusiasts. The BK75 features customizable RGB lighting, mechanical switches for a satisfying typing experience, and programmable keys for personalized functionality. If you’re in the market for a new keyboard, be sure to check out the BK75!
Media
Features
- 82 keys gasket mount design, hot-swappable switches gaming keyboard
- Wrist rest, dust cover, keyboard display stand 3-in-1
- Use the Hall switch/sensor, the keyboard will automatically turn on or off when the Wrist rest is covered or spread
- Removable magnetic keyboard top metal cover
- Bluetooth+ 2.4G+ Wired, Supports up to 3 Bluetooth Devices, Low-latency Fast Response
- Full-key with Rogers Poron Switch Pad
- Customized POM switches, office or gaming are both suitable
- Two-stage system switch and footstand
- The wrist rest can be used as a dust-proof cover, which in turn can be used as a keyboard display stand.
- The wrist rest is detachable.
- The contact surface between the wrist rest and the wrist is made of aluminum alloy, and the overall touch is delicate.
Hall switch/sensor intelligent magnetic control power supply
- The Hall switch controls the keyboard light through the magnet on the handrest and the switch device inside the keyboard
- When the handrest is turned over into a dust cover, it can automatically power off and sleep.
- When the handrest is unfolded, the power can be awakened to resume normal operation, preventing the dust cover from being accidentally touched and effectively protecting data intelligently.
Pre-Order Info
- Pre-Order Price: From 72USD
- Pre-Order Time: 29th Dec 2023 - 12th Jan 2024
- Sale Format: Unlimited
- Estimated Shipping Time: Shipping in 3 business days after GB ends
- Vendor: Velocifire (Worldwide)
Content creators (TBD)
Edwardtanujayaa
Low Tech
Samuel Tan
keekskeebs
Arctic Buys
Specifications
- Brand: Bat Knight
- Keyboard name: BK-75
- Number of keys: 80/82 keys+1 knob
- Mount: Gasket mount
- Product net weight: 1.4KG
- Size: 327mm*150mm(Wrist rest 90mm)*46mm
- Front height: 20mm
- Connection: Type-C
- Battery capacity: 4000mAh
- PCB: flex cuts, 1.2mm thickness
- Wireless transmission distance: max around 8–10 meters
- Backlight: RGB, with programmable software
- OS support: Compatible with WIN, MAC OS
- Anti-ghosting keys: Full keys
- Cable length: 1.5m
Keycap
- Material: Doubleshot PBT
- Process: Five-sided sublimation
- Thickness: 1.5mm
Switch
- Name: Bat Knight Orchid V2
- Type: LinearRating: 50 million presses
- Actuation force: 40±10gf
- Bottom out force: 50gf
- Actuation travel: 2.0±0.6mm
- Total travel: 3.3mm
- Standard factory lubed only
Polling rate
- Wired, 2.4G: 1000Hz
- Bluetooth: 125Hz
Working voltage: DC 5V±5%
- Wired: DC5V±0.5V
- Wireless: 3.3V–3.7V
Working current
- Wired: ≤500 MA
- Wireless: <210 MA
Follow us for the latest news on our products
Please feel free to ask us any questions and welcome to join and follow our Discord and Instagram for more discussion and updates, thank you so much!
