[Pre-Order] WeiKav NUT65 Dynamic RGB Light Bar Ball Catched Tri-mode 6000mAh Mechanical Gaming Keyboard Kit
Hey everyone!
Today, we are excited to introduce the all-new Nut65 mechanical keyboard — a stunning blend of advanced craftsmanship, customizable features, and eye-catching design. Whether you’re a gamer, a creator, or just someone who loves quality gear, Nut65 offers a premium experience like no other. And the best part? Pre-orders are now live! Don’t miss your chance to be among the first to get your hands on this incredible keyboard. Keep reading to learn what makes Nut65 so special!:chestnut::chestnut::chestnut:
Highlight of NUT65
  1. Pure CNC carving craftsmanship with 220 mesh anodizing/electrophoresis for an ultra-premium feel! A total of six colors for you to choose from. (Anodized Black, Anodized Silver, Anodized Red, E-coat White, E-coat Milky White, E-coat Pink
  1. Three-mode connection supporting multiple devices and scenes! Can pair up to 5 devices, with quick switching to connect 3 Bluetooth devices. Optimize the wireless connection module, making it more stable and smooth, and allowing for seamless multitasking.
  • FN+Q/W/E to switch Bluetooth mode
  • FN+R to switch to 2.4G mode
  • FN+T to switch to wired mode
  1. 8-pin magnetic contact pins for easier disassembly and assembly! In order to increase the anti-oxidation life of the pin and the connection stability, the touch pin adopts an 8-pin transmission, which improves the customized keyboard experience in many aspects.
  1. Quick-release structure for effortless maintenance and upgrades! Equipped with a new ball model to optimize the pulling force, achieve better disassembly strength, and achieve a silky, quick disassembly effect. Anti-collision silicone is added to the four corners of the keyboard to achieve soft contact between the top and bottom cases.
  1. Self-developed web interface + VIA dual-driver, allowing personalized customization with ease!
  1. Dual gasket mount with a plate gasket and PCB gasket — delivering an outstanding tactile experience! Two different structures can be freely modified and switched, allowing you to deeply experience the fun of customization.
  1. And the most impressive features include:
    Four-segment RGB light strip at the front, built-in microphone, with lighting that “dances” dynamically to music!
Four dazzling lighting effects:
Flowing light from left to right
Flowing light from right to left
Central to both sides’ diffusion
Both sides are converging on the center
  1. Detailed upgrade: The spacebar is equipped with five LEDs, making the lighting more vibrant and colorful!
  1. The back of Nut65 continues the Weikav multi-process design concept, with storage compartments, decorative parts, anode back plate, metal patches and other designs, and a variety of processes create a textured back design.
  2. 6000mAh large capacity battery
Showcase Video
:rocket: Pre-order ends on August 14!
Order processing begins on August 15!
Pre-order now to enjoy a 20% discount — don’t miss out!
Purchase
With a 20% discount, the price will be 63.2 USD
Specification
  • Layout: ANSI layout
  • Mount: PCB Gasket Mount Structure
  • Case material: CNC Aluminum 6063
  • Processing: High Quality 220 mesh Anodization & e-Coat Finishing
  • Quick Assembly System: Ball-catched
  • Anodized aluminum weight with dongle compartment
  • Sound-activated RGB lighting effect
  • Flex Cut 1.2mm Hot swappable PCB, South Facing RGB
  • Horizontal Flex Cut FR4 Plate
  • Padding: 4 Layers
  • Connectivity: Wired / 2.4G / Bluetooth
  • Battery: 6000 mAh
  • QMK/VIA compatible
  • Does not include switches or keycaps
  • Dimensions: 31411319.5 mm
  • Weight: 1.12kg
  • Including: Keyboard1, Keycap&Switch puller1, USB cable, Manual
  • Manufacturer: Weikav
  • Web Driver
