I ended up deleting all my pics on it from instagram because my application testing was done on what I had laying around (MX) and the final feel testing was done on alps.
somehow people suddenly assumed you can ptfe powder lube mx switches, I would not recommend that. the powder will fall off and clog up the plunger hole, the leaf etc. it’s safer with alps.
I’ve also heard this the best way to apply to PTFE powders, as just like @homerow said, if you just dry powder lube parts the powder will not stick well, inevitably fall off, & even possibly clog up parts of the switch if enough is present. I have heard of people having success dry powder lubing SKCM ALPS stems, but personally even there I would go the ISO soak & dry route or PFTE spray + bag route @Nebulant mentioned.
