Okay hear me out now. Ridiculous Sound Mods for your keyboards.
Imagine making this cutout and mounting your keyboard. All about that bass
Edit: No bottom on the keyboard case to let the sound fill the sub box
Any other wacky and wild ideas?
A plate made from a banjo drum, pcb just hangs out in the back all open like. Twang instead of thocc.
We got to include this guy! - - YouTube
I’d like to hear a keyboard in an “Anechoic” room aka quietest room aka negative DB room
Mechanical keyboard with futuristic looking air pressure plates on the sides could be cool.
Oh! A keyboard activating air pipes would be interest…
I’m describing an organ aren’t I? ![]()
I have a harebrained idea to use piezo elements on the underside of a PCB or inside a case to generate a signal to feed into some sort of audio circuit or analog synthesizer. The dream is a keyboard that “plays” some kind of generative soundscape as you type on it.
Absolutely no clue about the feasibility. The farthest I’ve gotten is amplifying a K70 with a piezo array and running the signal through a couple effects pedals. That sounds you can get are pretty funny but using a distortion pedal to make it sound like you’re typing with a machine gun gets old kinda quick lol I plan to start working on the project again when my Saturn60 ships, it looks like it has a bunch of room inside the case so I’m hoping I can get it wired up.
Someone just needs to merge an hhkb and an op-1…
