Anyone know of any SA profile keycaps with pudding style translucency or even just shine through legends? I bought the Womier k61 recently and I’m looking to get SA keycaps for it, but it really seems like a waste to get non shine through ones.
There are a couple of sets YMDK sells on Amazon (and probably other places if that’s not available to you). If you google “shine-through sa keycaps” they should come up. Can’t vouch for the quality, I’ve just seen them floating around.
Just a note to avoid the very cheap shine through SA from places like AliExpress. They’re not sculpted SA and the quality is pretty bad.
Having said all that - I don’t recall coming across any alternatives in my time. Good luck with your search.
