Hello guys!
I am new here and I am just starting out with this wonderful hobby. I have just recently recieved my Anne Pro 2 which i consider a great entry keeb. I am planning to mod it soon but I have already got my keycaps. They are a simple beige and grey set from KPRep. I wanted to go for a retro look so they seemed a great option for my budget. However, I have stumbled upon a problem of a sunk spacebard with the custom one (the stock one works perfectly fine). I tried googling for a solution but just nothing seemed relevant to my case.
My guess is that it is a matter of either bad stabs or warped (?) spacebard, though I am not sure what the second one means.
Would you guys be kind enough to propose some king of solution?
Here are some pics:
STOCK:
CUSTOM (sunk in):
