@CosmicKira Check it out - Tae shining some limelight on the Shinobi.
Saw that one and I defiantly agree with a lot that was said.
DIY, is the way to go. That way you can take it from being a ok/good board to being a good/grate board.
The things that I would still like to see changed are:
Did you grind your keycaps to get around the crosspoint? did you find a way to finish them to a point where it didn’t look super crusty? also how much fade did you incur on the original caps?
Enjoy
Tex Shinobi build
Tex Shinobi build continued
Pretty sure none of the audio came across, when I uploaded the video clips from my phone to imgur.
