Oh, on the Zoom65, that’s not wild green, it just just the standard black case from the Olivia Dark version, and the keycaps are Aluvia with the “hihihi” novelty enter key and a polished copper novelty ESC key. I also swapped out the lnob and bottom weight for the rose gold ones to match the rest of the build.
This was kind of my *first * “endgame” board.
I went with the full foam config, FR4 plate, stock WS stabs, and lubed Alpaca switches. I definitely feel like I got a return on my time invested, as it sounds great to me. Perfect summer board because between the keycaps and my wrist rest, the aluminum keeps everything cool.
The QK60, I went with the bottom case foam, no plate foam, FR4 plate, stock Owlab stabs, and lubed KTT Rose switches. Keycaps are Osume Mochi. It’s quieter than the Zoom65, but it’s so nice to use all day. Being wireless is also an added bonus.
I went WKL and split-backspace on my configuration because I felt it balanced out the top row, and I liked the shine-through of the blockers through the acrylic, but could commit to the HHKB layout.
The QK60 went together smooth as can be. The Zoom65 I followed the build guide because there are a couple of steps you need to pay attention to, but nothing too crazy.
Qwertykeys and Meletrix are both killing it in the “Entry Level” quality department.
alexotos has build streams/reviews on both:
Zoom65
QK60
You honestly cant go wrong with either one
