Intro
The Tsubasa keyboard cable is a dual Type-C plug 8K keyboard cable with a stable connection of ultra-low latency, compatible with magnetic and mechanical keyboards, numeric keypads, mouse receivers and other devices at the same time. But its real charm lies in its magnetic control global light effect system, where the two Type-C interfaces and the splitter main body emit light independently respectively. Non-contact intelligent interaction allows you to adjust and switch a variety of light effects without physical touch. The three light-emitting areas can be independently set with different colors and light effects, and can also be turned off or on independently, allowing any combination you want.
Highlights
Premium Material: Silver-plated true single-crystal copper core with pure copper hardware for stable transmission
Smart Lighting: All 3 modules light independently; magnetic control for color & effect switching, with memory of last used lighting state.
Craftsmanship: Purely handmade, exclusive customized connectors and terminals
Compatibility: Fits mechanical & magnetic keyboards (Wooting60he, Wooting80he, etc.)
Lighting
Lighting Effect Solution:
Full-Range Independent Illumination: The two Type-C connector housings and the 1-to-2 splitter main unit—three modules in total—can each emit light independently, creating a layered, three-dimensional light array on your desk.
Memory Mode & Independent Control: The lighting state automatically remembers the last effect used before power-off, so no reset is needed next time. Each of the three lighting zones can be independently set to different colors and effects, and can also be turned on or off individually.
Lighting Effect Modes:
10 lighting modes, switched via magnetic control
RGB Flowing Chasing Effect
7-Color Dynamic Breathing Effect (Red/Green/White/Blue/Cyan/Yellow/Rose Pink)
7-Color Slow Breathing Effect (Red/Green/White/Blue/Cyan/Yellow/Rose Pink)
10 Single-Color Static Effect (Red/Green/White/Blue/Cyan/Yellow/Rose Pink)
How to Control Lighting Modes?
Place the included badge top plate cover over the Type-C connector housing or the light-sensing area of the 1-to-2 splitter. A light tap switches the lighting mode; hold the tap for 3 seconds to turn off the lights.
Package Includes
Keyboard cable Witch Dual Type-C plug *1
Badge *1
Type-C Adapter *1
Mini Accents *2
Color Options
- Black Diamond
- Sakura
- Glacier
- Galaxy
- Obsidian
Vendor
Worldwide: KeyMaze
Pricing
69.99 USD (Coupon: 5% OFF for new accounts)
