Recently I’ve build UT47 keyboard and there is an issue with pro micro being too thick for the case. It’s not possible to tighten screws all the way on one side, as the bottom plate pushes against the usb socket of Pro Micro
There are two spots for Pro Micro and I was wondering if it would be possible to solder another Pro Micro upside down so that everything fits and do some kind of hacks so that everything works?
Also, are there any cases on the market that would fit ut47 pcb?
