I’ve been having trouble getting VIA to see any of my three compatible keyboards.
I’ve tried different cables, tried all the USB ports on my machine, even tried it on two different operating systems - so I figure I must be missing something, and probably something simple.
I’ve been able to flash plenty of boards with QMK, but I haven’t gotten VIA to recognize my NK65EE, KBD67L, or Portico. (Why, yes, I do love middle-market 65% keebs…)
Any tips for a VIA n00b?
Edit: I should note that the key-testing function in VIA does recognize inputs.
The NK65s should be plug and play with VIA out of the box afaik (mine was I’m pretty sure). The rest may need you to flash the via compatible hex file before via will allow plug and play use.
I never did manage to get plug-and-play going, but loading the .json manually works for me. (Yay!) I installed the beta firmware on my Portico, and the page has a nice short step-by-step.
I will note the current version I’m using will crash the software when clicking the “lighting” tab. From there I’ve had to restart VIA and re-load the .json, but it’s all good from there. (It also does include the default lighting controls, despite what the page says at time of writing.)
