I am looking at the new Keychron k3 pro. It would be my first mech. keyboard. From what I read there are few limits:
- Low Profile switches , keychrons website says The K3 Pro is currently compatible with Gateron low-profile mechanical switches only. Which means that I can only really switch between gateron low profile. How likely it is to be able to use different switches in the future?
2.Keycaps -AFAIK K3 didn’t have standard stabilisers for some of keys so they either couldn’t be replaced or if they did, they didn’t fit completely (not sure if it caused actually problems though). K3 pro should have different stabilizers, but I am not sure if it makes a difference and I could replace with any other low profile keycaps.
