Needless to say I was very disappointed in myself. Luckily I keep it in that eye screw so heat doesn’t transfer.
I’ve never seen this stab mod before! Looks like I’ll be keeping the backs of my deskeys films to give this a try.
Interesting…
I keep mine on a powerstrip that has my workbench light plugged into it. I use the switch on that power strip to turn on the light and soldering iron. That way, I know if my workbench light is on, the soldering iron might be on. As long as the light’s off, there’s no fire hazard.
I left my on accidentally a few times before I came up with the idea. I was terrified I was going to burn the house down. No more worries now.
I tried this mod for my stabs andit works great. It took a little bit of trial and error to get the size right for the deskey bits but in the end I would say the feel/sounds was worth it.
I learned that I can desolder, lube (albeit heavily) and resolder a prebuilt 60% keyboard!
Awesome confidence builder project! what switches and what board was it?
MX Cherry reds. I practiced on a cheap Ducky One 2 Mini I picked up on mechmarket. Really relieved that the other switches I’ve order aren’t a waste now xD
Nice, that’s probably a pretty solid board, if those reds got a little breaking in from their previous owner, I bet that sounds quite nice. what other switches did you order? planning another build?
Ducky does solid 60%s at least from my experience. I’m planning on switching out the switches on a couple other boards I have with Gazzew’s UT4’s and his Bobagum silent linear. Real excited for when those get to me in the mail!
sounds good, Gazzew makes some awesome switches.
There are Irons that have automatic sleep modes, like the KSGER T12 soldering station that I use (maintain the temperature to low 200 Celsius).
But it is always better not to forget to unplug your iron.
Apparently choc switches and keycaps are designed for 18x17mm spacing, not 0.75" like I have been doing all this time. That would explain why there are such gaps between the rows…
Today I learned to live with the moral uncertainty of supporting Dorp: MT3 on Boba U4Ts sound like they’re going to steal my GMK sets’ lunch money.
You really aren’t kidding - MT3 over thocky Bobas might be my #1 favorite keyboard sound right now.
TIL (or was reminded) that if you’re buying square-stem Box switches, NovelKeys is probably your best bet.
I have two small batches of Royals, one of which came from somewhere else and appears to have had at least a small handful of stem-breakers mixed in - between 5% and 10% of the bag.
Easy choice on which batch gets taken apart for bits, but dang - I’ve got a small handful of way too loose MT3 caps now…
Holy crap I thought the stock of those had run through or been otherwise disposed-of a long time ago ![]()
I thought so, too - but I’m also not too shocked. I think if you stick with familiar vendors on your side of [given large body of water] you should be safe.
I think I saw Minterly does this with the puffy, rubber style band-aids. No need to use Deskey films.
After my last build, I think I’m going to start trying this. About half the keebs I’ve built so far are silents - which are all the less forgiving when it comes to rattle. I’ve got loads of “empty” Deskeys sheets, so that works out at least. Now I just need to find nice, thin tape.
