Anyone knows where I can get some I’m interested in getting some good thock out of my board this looks like a good find but I can’t find any places to get it.
Check out the description of the video. Sounds like these might still be in production. In the past, I have bought parts from Gazzew directly. Other vendors will likely get them eventually.
My understanding is that these are either still in production or in the supply chain.
Keep an eye on the distributors at https://gazzew.com. I believe he also has a post on reddit if you are interested in purchasing parts or buying the switch parts disassembled if you plan on lubing.
