The Zeal60 is a great PCB. The per-switch RGB LEDs are the obvious reason for the higher price, but also, there are lots of little things. The tolerances are just about perfect for Holtite sockets. Each key’s switch pins are labeled on the front AND back, which makes it easier when you’re trying to debug why the ‘Q’ key is the only one not working and you’re looking at the board from the backside. QMK support is awesome.
My only complaint is that I wish the bottom row supported more layouts. I want split spacebars and support for a proper HHKB layout (1u - 1.5u - 6u - 1.5u - 1u), and unfortunately neither of those things exists on the Zeal60 today.
That “HHKB” layout makes me so sad. I get that 7u spacebars make a fully-symmetrical layout and it looks appealing, but the usability is horrible - I always use my thumbs to hit the Alt/Cmd keys adjacent to the spacebar, and with the 7u spacebar, I just can’t contort my right hand to hit the keys to the right of the spacebar comfortably.
If it supported the asymmetrical 6u HHKB layout (1.5u blocker on the left, 2.5u on the right) then I’d probably buy two, but now I’m sad.
With conversion rates and customs (since to my knowledge the US doesn’t have a trade agreement with the EU that would cover this, see GMK) wouldn’t it be close to the same price as a B stock zeal?
also please tell me they will have US (or Canada!) based vendor heh
I ended up picking up a DZ60 to replace the Zeal60 in my TINA-A. Split spacebar and USB-C are worth giving up per-switch RGB LEDs, at least for me. I spend way more of my time actually typing things than looking at how pretty my keyboards are (although, don’t get me wrong, I spend a lot more time than any normal person on the latter as well).
That’s a good point. I touch-type and rarely look at my keyboard, even though I have the “fingerprint reactive” animation set on my K-Type. Maybe I can live without backlighting …
No, I have a Hammer case, so 6.25u, and the modifiers that fit with that, so not exactly ‘proper’, but better than the 7u option. Keymap is setup like HHKB, plus the extra keys. Been a long time since I’ve looked at the bottom row options, but at the time, I was happy with the options available before I built.
I’m typing on a HHKB right now, but switching between this board and the Zeal60 is basically seamless.
