Need some recommendations here.
I have both V2s in 67g & 78g. I am finding the 67g too light and 78g a little heavy.
Any good recommendations for a spring that that would retain the original feel of the switch as much as possible? I assuming they are progressive springs stock.
I would assume stock zeal springs to be liniers.
One thing I’d note about replacing Zeal springs; their rated weight is usually a few grams off from the rated weight of bare springs. IIRC Zeal’s 67g switches are pretty close to a 65g linear spring from SPRiT or TX. If you want something slightly lighter than the 78g maybe go for SPRiT’s 72S springs.
