Leaving this here for anyone else who may be looking into powder coating in beige.
I recently ordered some swatches from Prismatic Powders.
Sandle Grey, Oxford Grey, and Brighton Beige. All finishes in a River texture.
I figure photos are useless without some references so here are some things you might be familiar with
Top: IBM Model M keycaps
Bottom: GMK 9009 keycaps
And here they are next to the samples
And here is the scene setup for matching the IBM Model M SSK case
Left to right: Brighton Beige, Oxford Grey, Sandle Grey
Comparison to cerakote Light Sand:
And space65 e-coating in cream:
CA66 in “cement gray” powder coating:
The photos look fairly accurate to what my eye sees in real life
The Sandle Grey seems a bit dark. It’s close to the darker modifier beige. It might be the same color as the cement gray used on the ca66 but the river texture makes it appear brighter.
The other two are both great candidates for beige. I would recommend Oxford Grey if you want a classic beige that is on the slightly warm side. If you want something a bit fresher and brighter, I would say go with Brighton Beige.
Also curious @norbauer are any of these the color used for the TNG console color case?
