I asked in this thread whether Tribosys 3203 (which is currently on GB phase) would be good lube to make some Ergo Clears. I was told by OP that, while such lube works great for tactiles, it might provoke a somewhat muted sound.
Since I didn’t want to hijack that thread, I created this one for asking you guys which would be a good alternative lube for Ergo Clears.
I’m a beginner in the switch lubing game, so sorry if the question is a bit silly, but… what would be preferable for tactile switches such as Ergo Clears? Thin or Thick?
I’m on the same boat as @heroyjenkins. I’ve been a really big fan of VPF 1514 lately (planning on buying a half oz bottle for myself). I only made my first batch of ergo clears with them last night (historically I’ve used the techkeys thin blend), but I have high hopes for them. I’ll probably be using those switches tonight for my next build.
@Quakemz would be a great source of knowledge to PM on Discourse or Reddit for possible lube suggestions.
I don’t find that 1514 does anything for stems feeling-wise. Side by side testing with fully lubed (1514) stem feels exactly the same as non-lubed. Sound-wise it dampens the clack a bit. 1514 is great for springs though. Squeaky spring? Put some 1514 oil on it. I usually dip my springs in 1514 and let them dry off on a paper towel.
I’ve been using GPL 204 on all of my stems lately. Most people would tell you not to use a thicker lube on tactile legs, but I really like it on my clears. I favor the way a thicker lube feels on tactile switches. I think that’s why it’s important to try it out for yourself and don’t just take other’s advice blindly.
I haven’t made ergo clears, but I love a thin layer of 3204 on 67g zealios. It may take a little bit of the sharpness out of the bump, but the tactility is by no means dampened. Then again I like noticable, but smooth tactility (hence, why my Box Royals are collecting dust).
