The laser cutter I’m working with on Modern M0110 can do fairly low MOQ cuts at reasonable prices, so curious if people are interested in a 1.2mm (i.e., Alps plate spec) thick brass plate for the AEK 60% layout (based on Hasu’s open source design). Can probably get the group buy done at any quantity at or above 10. Thickness wouldn’t be exactly 1.2mm but really close to it (0.05 inches or 16 gauge is the spec since I’m in the US–works out to ~1.27mm).
Price would likely be in the $40 range before shipping.
What do you all think?
