Hello folks. First off, thanks for checking out my keyboard! Here’s some beautiful renders produced by Egla from the International Kit:
Click here for moreWith this board I aimed to create a board with a subtle signature that was easily recognisable. To this aim I’ve got a few unique features. First off I have a straight line at the front and back of the board accented by the plate itself stepping through the sides of the case
In the original design this was designed to be Blue with a brass plate to accent, hence the name which is Dutch for “on sea”
I’ve also included a slight slope raise of height between the front and the back of the board to surround the caps a little more, higher at the back than at the front. It’s 7mm at the front and 9mm at the back. It’s a small difference but, for me, it creates a unique structure to the board.
It has compatibility with a tada68 pcb and I intend to share the plate files so you can always custom cut additional plates if you need. So far I have my vision of the buy structured like so:
25 units in aluminium, all numbered 1-25. Choice of 6 colours for all aluminium parts.
10 units in polycarbonate, separately numbered 1-10.
Features:
7-9mm High Profile
Sandwich Mount
5° typing angle
Separate ISO & ANSI plate
.5u blocker for arrows
Polycarbonate or Aluminium body
Polycarbonate, Aluminium or Brass plate
Sandblasted Brass weight
Sandblasted Brass or aluminium name plate with custom lettering
Custom PCB (South facing LEDs)
Custom colours have been selected by me following some samples from my factory. I have chosen 6 colours in total:
Charcoal
Aubergine
Olivia
Ocean
Royal Green
Anthracite
Click here to see an album of the colour samples.
I have produced a prototype of the board in polycarbonate which helped me to learn a lot about the positives and negatives of the original design and tweak based on this. Changes include: raising the top piece 1mm overall. Dropping the overall height of the board 6mm. Adjusting the nameplate and weight mounting. Changing brass from polished to sandblasted.
Here you can see an album of the prototype
I’ve also worked closely with a designer to come up with a slightly fresher feel for the board, changing the font used from the prototype and changing the logo to a completely new design, I’m really happy with the work she did and have to give her a huge shout out here: Morgana on Twitter
I have implemented the changes in the working design and they will be in the final parts
You can see the proposed redesign here:
Due to the limited run of this board we are looking at a price of around $425-50 US per board (not including shipping)
Additional parts prices would be structured like so:
Plate $80
Nameplate $25
PCB $50
I plan to run this buy in november assuming this IC is well-received
