[IC] MT3 Extended 2048
Extended 2048, a minimalistic icons-based set inspired by the legendary AEKII keyboard is coming back in MT3 profile!
It now features some nice accents colors and more compatibility.
The Group Buy is scheduled for December on Drop (link soon) .
Kits
Alphas kit
Katakana Alphas kit
Modifiers kit
For any layout between 60 and 110%
Accent Modifiers kit
Modifiers kit color extension
Nomad kit
For any layout below 60%
Accent Nomad kit
Nomad kit color extension
Icono kit
Novelties
Media icons kit
Ergo kit
Numpad kit
ISO Intl kit
Covering most of European layouts
ISO UK kit
Spacebars kit
Colevrak kit
Homing addon kit
Renders
By the one and only Oblotzky.
Rama M65-A
Rama M65-A
Rama M65-A
Keycult No.2
Keycult No.2
Kai
Kai
Ion Zenith
Ion Zenith
HBCP
HBCP
Omega60
Omega60
Samples
The prototyping phase has already started!
I received some samples and it looks really promising.
The legends aren’t 100% centered on the cap but it will be definitely fixed.
Note that the backspace and return icons are outdated on the pics below.
The pics are in greyscale because the colors weren’t matched yet.
Thank in advance for your feedback.
Yes, more MT3 please.
Trading in my minimall funds for this I think! Either way I’ll be in on this.
The last 3 renders look white compared to the top ones that are more creamy. Is the set color matched to AEK caps? My aek caps are more on the beige side
All the renders are using the same colors which are GMK L9 and GMK BV :slight_smile:
Looks like I know what I’ll use my free MT3 base set coupon on :grin:
Love the icon set
I am soooo buying this for my Brutal60 and Preonic! Looks really good!
Looks awesome. Does MT3 have a R3 1.25u mold? Needing it for a sub 60 layout.
Edit: just saw your reply on the geek hack thread. Does not exist…
Double edit: seems that other MT3 sets have this key size for R3. :man_shrugging:
Would it be possible to add one more non-accent 1.5u R4 key to the Ergo kit? That would allow it to cover the Sol2, Boardwalk, Pan, and a few other layouts. I have Milkshake on my Sol2 and ended up using R2 caps on the bottom row, but this only worked out because I had enough spare R2 keys from the Colevrak+ kit.
This looks good, even though I want some black on grey key-caps already.
Which color is the actual one? Renders and the proto look quite a bit different.
EDIT: Saw your reply :slight_smile:
EDIT 2: The more I see this, the more I want it.
EDIT 3: Alpha+Nomad+Icono
Yes!
Add an ortho kit to this please!
I believe ortho is covered under the Nomad kit.
Yeah and adding the Icono completes it.
This is an instant buy for me. I e of my all time fav sets design wise now in my fav profile. Sold!
This solves my problems with XDA Oblique:
  • It was XDA profile
  • That’s it that’s the list
Looking forward to more!
This is the opposite for me, I don’t think there is any colorway/set good enough to get me to buy another MT3 set, even though this set is awesome and I regret not getting the epbt version.
Yikes. Which MT3 set didn’t work out for you?
I have two sets of devtty, it’s just not pleasant to type on at all imo
What are your thoughts on SA?
