Post Your Keyboards!
ohhhhh yeaaaa, very lovely weight you got done there :slight_smile:
That’s phenomenal!
it looks like its from the future
do you know if it can be connected to other devices?
nice texture and detail its seems japenese
Nothing new but took some photos of my BD60s this past week. Excuse the photo dump >_<
Lilac photos
Bruce Lee Banana photos
I also forgot I had hopped on the DK1-TKL train when it ran and it was a happy surprise when it showed up at my door. Apparently the plate is meant for clip in stabs, and they shipped with PCB stabs and didn’t bother updating the plate or foam to reflect the rotated Enter key stab either. Had to hand file all the stab holes on the alu plate and add notches for the Enter stab wires. Still, it’s super solid, sounds great, and is my first metal TKL. Been using it and I actually kind of love it. Not fully converted because I miss my function keys but this sounds/feels so nice..
Yeah, I like it, though as I understand the provenance, mine is from some sort of pre-production run and I had to manually edit the json to make it work in VIA, though I think the plate stabs were already there. I have KAM in it, and it’s really pretty and way closer to my preferred ergonomics, low height and shallow angle, than most customs and semi-customs I’ve seen. It’s also such a dense brick that it blunts the sonic impact of the Box Navies I put in it.
lmao
I’ve been using it without a wrist rest because it’s just low enough I can float my wrists without ache.
Taken from the Unikeys discord. They definitely messed up on sending PCB mount screw in stabs with the board though. I tuned into Alex’s stream for a second and someone commented “make suggestions to GDK but they won’t listen to you anyway” lol.
I still love the board. I noticed my Backspace is a tiny bit sticky and it’s killing me. I’d have to disassemble for the 3rd time to file the plate down some more :sob:
Completely new to VIA keyboards. Just got a new VIA keyboard RK R65. The typing is quite smooth. Plan to switch to shine-through keycaps
Nicely paired keycaps and cases :+1:
Think this is the final form for my new F1-8x V2 Mint/Mint. GMK Black Snail L9 Alpha/Mods + L9 Hangul (light shellac coated). HMX Retro J. TypePlus Stabs + Knight V4 stabs for spacebar.
Build notes: TypePlus stabs are really nice. You don’t really need to lube them. But, lubing them for SB made it extra loud so I swapped it out for Knight V4. I had some annoying vibration issue in the arrow cluster using the alu plate. I ended up placing a thin piece of electric tape to dampen that corner. Overall a very nice keyboard. Tbh, it’s a bit too heavy for me with all the weights. My son tried it out vs his Realforce R2 (pictured above) and I prefaced it by saying this is an endgame keyboard for many. After a few minutes, he told me “they sound nice but I rather use Topre.” I’ve never been more proud to raise another Topre fan.
Wonderful!!! :clap: :clap: :clap:
ive never seen a f1-8x v2 before it looks great :open_mouth:
love that case color :heart_eyes:
agreed
EC Nasu with GMK Muted and heavy domes thanks to Dynacap and Cipulot for the PCB. Had to dremel the PCB on some edges to fit into the case (RIP underglow and indicator lights).
wow that is one remarkable keyboard
Happy 40s day! :partying_face:
