Post Your Keyboards!
And of course I have to ask…
does it glow?
Damn that’s hot
Wew, that’s nice!
The other Noxary Vulcan. This time with red body and silver bottom, and brass plate. Built with MX blacks and 3204.
so clean
Perfection. How is the typing experience?
The brass plate makes it stiffer than the other setup which is alu + tactiles. Still, it’s so far the best sounding 60% brass plate kit i have, same thing for the feedback i get with keypresses. Especially the spacebar.
Is that a GMK set? If so, which one?
Yes it is. It’s GMK Classic Retro with the Korean beige alphas that was run separately.
Took some pics of CRP Tulip on a navy blue Verne and GMK Nautilus on a polycarbonate Percent Canoe
That Verne is gorgeous! Will Jules be offered in that shade of navy?
The plan is to offer a dark blue version, but no powder coat
what foam did you use?
mkultra 4mm plate foam, ~2mm foam i got at michael’s and cut myself under the PCB.
awesome. Waiting for some 4mm mkultra foam for this exact same build.
Nice. One thing to be aware of is 4mm foam won’t fit between the PCB and bottom case, I tried with one from mkultra and it was too thick.
My collection is slowly being taken over by alps
Do you have a favorite?
Hmm that’s a tough call. I think if I had to pick one, it’d be the orion, since I love the way brown alps feel and sound. But each one brings something unique to the table, so I find myself swapping between them all constantly.
