That set looks so good on white.
Susuwatari looks great on anything! Love it. Gonna have to dive into linears soon enough myself.
What’s going on with the shift there?
Exclusive mt3 redacted
My thoughts exactly
Haha. Very exclusive.
do you notice the “chrome” wearing off at all / how does it do with fingerprints/oil?
I haven’t had any issues with wear, but I try to be pretty careful with it, I wipe it off with microfiber after I get it out and don’t tend to touch the case much while using
i should have specified my question was regards to the keycaps.
Oh the keycaps are like some super cheap “metal coated” plastic crap I got for like $20 they feel pretty bad tbh
VULCAN+KBDFANS MAJAPAHIT
FR4 Plate, FFFF tactile switch with Kiwi stem, FFFF stabiliser, Maxkey Virtual War keycaps
What glorious Alps live under those SGI caps? Is that Orange?
I have the same caps, waiting for a build
Yep it has a really nice batch of SKCM oranges I was able to snag a few years back in it. Although I ended up linearizing them cause they are easily the smoothest batch of SKCM/L ALPS I have.
PS: You’ll love the caps when you get to put them to use, don’t forget to show us your build when it’s finished too!
Awesome! I have linearized Blacks in another build of mine and they are great. Alps linears have some resistance at the top, which makes typing on them more fun than MX linears. And the sound is so good.
That is awesome. If I was female I would have your babies.
