I’m still on my scuffed gmmk with lubed stock (ew) stabs, silent forest 62g switches, and a kbdfans pbt dsa set.
I relubed and clipped my gmmk full stabs. It’s the board I run in Homeoffice
I have some durocks coming for my gmmk, and I also have a whole another board in the works… Maybe posting here in a week or 2 when it’s built.
The shine on those keys indicated that you’ve gotten your money’s worth or more out of it!
Pretty much yeap
I like the kbdfans DSA-kits, they are surprisingly well-made for the price.
I have two of them myself, one used for dye-experiments
It’s a pretty good ket for the price. That being said I will be upgrading for the new keeb. Probably going for GMK. If that doesn’t work out on the new board, I guess I could just get a higher quality DSA set.
Would love to see carbon on one of these cases.
FYI the GMMK uses plate mounted stabs while Durock is pcb mounted.
But I like the caps, I had exactly the same on my GMMK.
there are plate mount durocks
We’re?
Everglide also makes good ones with gold plated wires that you can get from Kprepublic.
I put my Preonic back together and am using the default layout with some tweaks, and Boba U4 62g in them. I can’t quit this thing.
Don’t know, they haven’t arrived yet.
Ortho best
I haven’t wanted to use any of my other boards after getting my preonic. It lead to me ordering a id75 as well!
Plan for the 75 is to add a number pad to the middle turning it into a split board of sorts.
Homeoffice time and this is the stab modded Homeoffice board. I will at some point lube the browns on this board. Once my solder sucker arrives I am thinking of putting red silent stems int he brown housing and see how that feels
