Finally got my G60 in NCR color way. Built with a POM plate and weirdflex PCB. This is without a doubt my new favorite keyboard to type on. It’s incredible
What switches?
Milky Gateron black, lubed with Krytox 105 on the slider and 205 in a few other spots with thick thock marshmallow springs and TX films
I appreciate that you replied to me directly knowing that I specifically needed to see this beauty.
Nice one, do you have a reference for the deskmat, i like it, simple and it looks thin
I purchased it from Amazon.
Thanks
What do these types of backgrounds look like?
Rama u80 Lake
Aluminum plate
Creampacas lubed with 205g0, 63.5 Sprit slow springs, Deskey films
KAT Blanks
Typing experience is a bit stiff after using a Thermal for a month. Then again, probably everything is stiff compared to a Thermal.
Love the positioning of the superlight in the reflection of the weight, looks great.
Can’t wait to hear how your new cables work.
So, they’ve arrived. Not the cables, but I’ve ordered magnetic extensions for existing USB-C cables and bunch of insets for USB and Lighting ports.
I am using it only for a bit so far, but I am happy.
Also, maybe just because I’ve ordered bunch of the magnetic insets for the ports, I’ve got a nice little carry bag which I guess they usually send cables in.
Also, the port insets work really well with recessed ports - on the photos is my Tofu case.
Magnetic solutions are great but there is a hidden downside. I’ve used a particular brand’s cable and tips for three years or so, but they recently discontinued the model that I was using, and finding additional tips for my expanding board collection is not an easy task. The company is still making cables/tips, but have moved on to new models that are not backwards compatible. My suggestion would be to buy more tips than you currently need if you’re sure that your board number will increase in time.
These are pretty nice. Plus they add a little flare when connected.
https://www.amazon.com/NetDot-Magnetic-Charging-Transfer-Compatible/dp/B07QCT91HG?ref_=ast_sto_dp
Wow, same keycap set as mine. Also on Tofu?
